Hi all. Wonder if you can advise. I would like to adjust the ride height on my newly acquired ST4. Sachs shock with integral bit on the top for adjusting the rebound I think. Trouble is I cant seem to get a spanner on to the adjuster ring on top of the shock to tighten it downn.
Is there a knack to this as space is very limited. Cant make out if this is a stepped adjuster as per Jap bikes or that the ring needs to be tightened down on the threads of the shock body. Advice please.
Cheers. BRIAN.
Cheers. BRIAN.
