Rear LED Brake/tail
Geoff
Hi,
I made this LED array for my monster and looks good. You can easily vary the number of LED's but the one's I used are square PCB units and limited them to the number shown. It draws a fraction of the current required by filament bulbs and isn't effected by vibration. Anyway for someone that has access to PCB making facilities or veroboard then I thought they might find the schmatic useful.
Geoff
i knew someone once, who maybe made some of the besterest tail lights eva for the monster , he might even make some more one day, soon :watchout:
can you explain that better ?
how on earth would current leak to earth?
surley its either on or off depending on the lights switch or the break light switch
Diodes
Hi,
Basically the circuit shares the same LED's for both tail and stop. In order to change the intensity you must alter the current that flows through the LED's which requires a change in resistance hence 47ohms and 680ohms. The tail light is always ON and hence D2 is forward biased alllowing current to pass through R7, R8 etc. However a small amount of current will also pass through R1,R2 etc. Once the stop is pressed then D1 and D3 are also forward biased and all current will flow through the LED's as the voltage on the cathode will always be less than the anode which is effectively connected to the battery through some switch. In effect it stops current being lost to some other part of the bikes circuit. Complete isolation unless the diodes go faulty??
Geoff
LED's
Hi,
The choice of LED intensity I suppose is down to user. The one's I used deliver 900mcd with an If around 5mA which I find bright enough. The final intensity depends on the If flowing so it's possible to dull down superflux devices by reducing the optimum If current. Running them at 10,000mcd - very bright indeed - you'll be seen!
Geoff
