Has anyone tried one of these from M&P? My Monster 796 feels like it is running a bit week, is this a relatively cheap and simple solution or just a waste of £70.00?:dunno:
These devices work by altering the output from the air temperature sensor so that the ECU richens the mixture. There is nothing fancy about them but it will probably improve the low end fuelling.
An alternative may be a FatDuc which alters the signal from the Lamda sensor, producing a similar effect.
Some more about the Procom here
Thanks for those links Derek. It looks like the fatduc enrichens the mixture all the time and from the blurb, the procom enrichens it on opening the throttle but has little or no effect on constant throttle opening. To me, the procom seems a better solution but the reviews of both seem positive.:thumbs: I'm going to replace the exhaust mid section which has the servo driven valve with one from a 696 Monster too to get rid of the obstruction in the tube, get rid of a potential problem and hopefully make it look a bit less cluttered in the under seat area. Do you know for definite if I will need one of these servo eliminators or not. Some posts on the internet say yes, others say they didn't need the servo eliminator as they don't have the indication on the dashboard display.
For your bike, I don't know but you'll find out soon enough. When the butterfly is jammed in the fully open position there is next to no obstruction. That would be a lot cheaper than a new pipe.
I know Derek, but I don't like the cluttered look of having that valve there so want to get rid of it if I can.:lol2:Like this View attachment 11460 and not like this View attachment 11461
Just an update really, I have bought a Procom and the mid section exhaust so will find out if the mod is any good or a waste of money in due course. Hopefully it will be the first option! :dunno:
