Has anyone had issues with poor spark from the coils?
Bikes in pieces chasing the fault. Even stripped the loom back to check a common joint.
Wiring diagram differs from actual bike. Doesn't help.
Tested coils as per Beru technical across both HT sockets and get 15k ohms approx.
1.5 ohms across supply pins. Even HT leads check ok at 6ohms approx.
YouTube shows to test between supply pins and HT side but open circuit and don't think this is the correct method for the coils.
Ecu earth fine.
Anyone had issues with the starter motor pulling current down?
Going to crank over with spare small car battery later to test.
Genuine manual doesn't show coil test. Just to plug in their handheld unit.
No faults from ecu using jpdiag. Cleared old faults. Had full list almost.
Starting to chase my tail a bit now.
Ecu earth fine.
