Please help - Splitting air-cooled head and barrel
monster_998
Motivated by my new engine stands and some temporary extra space in the shed, I actually manage to do some work on my Monster today.
Plan was to whip the horizontal head off to get in the house for shim measuring and a clean up. I got the head stripped as planned but after removing the head bolts I'm struggling to separate the barrel and head. The barrel is separated from the crankcase and the complete assembly moves freely on the studs but they seem to be stuck tight.
Any advice?
Get a bit of wood that will fit in the barrel, stand the bit wood on it's end then holding the barrel, whack the whole lot down over the wood. Hopefully the head pops off.
<EDIT> Re-reading, you want to leave the barrel in place? Forget all of above. You need the King of hammers.
The only thing holding them together Graeme will be corrosion. It is a simple spigot joint with no gasket. Try to hold the barrel down while you whack the head with a rubber mallet. Alternate blows on the inlet and exhaust sides should get it off - eventually.
I remember reading that the one thing NOT to do is use anything metal to try and lever between the barrel, the alloy fins and mating surfaces can be easily damaged.
Watch what and where you are hitting, but keep in mind I can always weld fins back on for you.....!:lol2:
The gentle persuasion continues but definitely avoiding the fins :)
I appreciate the offer, which I may take you up on this as one was already broken.
Head and barrel are now separated - with some additional, but very gentle, persuasion from a crowbar :)
Many thanks for all the replies.
