Petrol tank problem with Sport Classics
Derek
I have been reading on another forum that there is a known problem with the polycarbonate petrol tanks on the Sport Classic range. Apparently, over time the tanks are distorting resulting in the front of the tank spreading and no longer locating into the mounting brackets on the frame, leaving the tank only held by the bolt at the rear.
There is an article about it with a "fix' here
thanks Derek, the problem seems to affect all of the SC range and there are also a lot of comments on SC tanks blistering and bubbling :( . There are a number of threads on ducati.ms discussing this with some very real concerns over how safe it is to ride with a tank that isn't retained correctly. From what I can gather most of the affected bikes are in the US and Ducati US is not replacing them outside the warranty period :( I don't think they have the same Sale of Goods legislation regarding fit for purpose as we do here, if they did they'd be able to use it for a defect which is there from manufacture even up to 6 years on, its fairly clear that the design or material / construction is incorrect if a tank distorts.
There have been quite a few multistrada owners on multistrada.net experiencing the same problem as the multi also uses a plastic tank.
However, I have yet to hear of one with the problem outside the USA, and I think it could be due to the increasing use of ethanol mixed in with the petrol over there...
There is absolutely no chance of a Multi tank falling off - even if all the bolts dropped out :D
You could be right about the ethanol mix though.
:eek: Good job my old SS tank is metal, given the amount of ethanol I use to stop the carbs icing up ......
Yeah, it's not the easiest tank to remove :D
Nice avatar by the way Derek! :thumbs:
Thanks Miles. Since we will now be seeing Ducat's new logo all the time I thought I'd try adapting it.
Here's a possibility for another SDC logo - or red - or yellow :)
...I told you all, you should have bought a ProjectImola, you wouldn't have had these problems with your tanks....
....you wouldn't have had tanks (as we know them), you would have had a small container for carrying your fuel!!!! :D
http://www.thetankshop.com/
Then again, you could always get one made.
Notice they also do polished alloy fairings and panels for ducatis.
Would make someone a nice christmas present.... eh Scott?;)
...the problem with this guy (Taff is his name) is that he does build a brilliant tank
From what I know of The Tank Shop; He wants the bike there so he can make it to fit. A mate arranged to get a tank made by him over a winter and trailered the bike 150 miles down to Dumfries. Four months later he still hadn't started. :eek: Since my friend needed his bike on the road he just had to fetch it back again and forget about the tank.
And he wants the bike there so he can make it to fit. A mate arranged to get a tank made by him over a winter and trailered the bike 150 miles down to Dumfries. Four months later he still hadn't started. :eek: Since my friend needed his bike on the road he just had to fetch it back again and forget about the tank.
Guys, think perhaps you should give thought to what is posted here.
Firstly my understanding is that the Tank Shop is run by John Williams who has had very good press recently about the standard of his work and featured in the Classic mags. How long he takes or has taken I can't comment except he has a 4 month lead in at present according to his website.
I am looking for someone to make a number of bits for a project bike I have and I have spoken to several folk around the country including John.
I have no doubt about the quality of John Williams work but what I said above about having a friend's bike for 4 months and not starting any work is fact. I have made no insinuations nor assertions as to why the work didn't take place.
The only point with your post would be that although you dealt with a factual problem that you presumably could substantiate is that your post included part of a quote from someone else.
:D
...The only point with your post would be that although you dealt with a factual problem that you presumably could substantiate is that your post included part of a quote from someone else.
Just thinking if the other post was pulled or edited you are still carying that quote...
Fair enough. I'll sort it.
I've amended my post and removed Eddie's quote, but I can't do anything about Ed quoteing me :o
OK, this now gets very complex, I cannot edit or delete any post, by doing so once it means i accept responsibility for the content of the site all the time and would have to check every word written. By not moderating the responsibility passes to the poster and they can be sued (Smith v's Williams, 2006). I have IP tracking switched on so could be requested by a court to provide details of the IP of the poster even if they were totally unknown to me.
The analogy I was given was that if you moderate and check content you become a publisher and as such could have chosen to remove content or not publish it ( like a newspaper would), alternatively if all you do is provide a place for people to visit that could be considered a wall, if someone comes along and writes offensive graffiti then you can't be responsible for their actions or even know it is there.
Libel for forum owners is still not fully defined and it could be that even this is not enough to prevent me being named in a legal action but I'd hope that wouldn't happen, if I get complaint about the content of a post and requested to temporarily suspend that post ( ie not delete or edit just remove from view) until the poster clarifies that they want it to remain I am prepared to do that. I cannot judge or make any decision on the content myself though.....
I have removed/edited my post, and understand that what I may have written wasn't appropriate. Apologies.
I have a fairly good idea who Eddie is talking about and am pretty certain this is a case of mistaken identity. I am not going to say who it could be but what is posted here is probably defamatory and it may be a good idea to pull the posts sooner rather than later.
I was referring to John Williams actually. I've never doubted his workmanship. :)
The thread above makes no sense whatsoever now :crazy:
Never mind at least it's not libelous!
true, sorry folks I voiced my opinion again in an open forum and it (almost) came back and bit me on the bottom. (It certainly did last time I did it...)
...might learn one day huh!!! :rolleyes: :o
Back to the subject of SC tanks..... A number of US owners have now completed vehicle defect forms with the NHTSA, according to one report I've read the fuel tank forms part of the emission control system ie unburnt fuel gets recirculated to it as such California state law requires a much longer period free from defect than a typical component as its part of that circuit, 7/8 years without fault being the numbers quoted. If that is the case and i've got no reason to doubt that it isn't it should mean Ducati have to replace tanks that do spread as a part of the guarantee. Once the NHTSA rule on it it would set a precedent for VOSA so UK owners should have protection although it does look increasingly likely that its the ethanol added to US fuel that could be the cause. Hopefully it won't affect us as I've got no desire to fork out for a tank!
