Oil
Phil_Superlight said:
Hi guys and girls is there any diff between car and bike engine oil, as in could car oil be used in a bike.
Phil.
Not sure, but would you really want to risk it?
Not in my superlight no it only gets the best :D but i bought another bike and was gonna drop the oil but didnt no if car oil done the same job i wouldnt use it though if i was unsure.
Phil.
Hi Phil, Car oil is different. If you fill a wet clutch bike with car oil. It will most likely cause the clutch to slip.
Ranald.
And there i was going to post it must be ok as one guy on the link provided uses the same oil in his bikes as he does in his cars, maybe be better if i go out and get some bike oil though just to be on the safe side :)
Your Ducati has a dry clutch and won't be bothered about car oil in it. Use a synthetic though.
i wouldnt use a car oil as generally speaking they are designed with different sets of use in mind, remember bike engines are generally speaking in a tottally different state fo tune from your average care so they often have to work a lot harder though the basic weights are the same ie10w40 the additives are different.......but thats just my opinion
In an engine like a Duke I'd always use the best possible (ie Sythetic) no point in skimping a couple of quid when it's the engines life-blood and you can rest a little easier when nailing it..... on private roads of course!
