oil warning light
Hi everyone,i bought a Ducati 750ss a week ago, only done 2000 miles since new (1997). Problem is we went out on it for the first time yesterday and the oil pressure warning light came on when we pulled into a car park. my hubby played about with the connection which was loose and light went off again, we went out again today and the light is coming on at tickover but goes out soon as revs go up is this common on these or is it more serious?
ps only does this when hot
could be water in the connection on the pressure sender bit
orr the sender could be on its way out
not the end of the world , replacments are cheap enough
so long as you know theres oil in the engine its only a idiot light in that respect
ooooor
since you say it only does it when its hot at tickover when the oil is less viscous it's exen less to worrie about you are useing the right grade of oil ?
Quite a common fault.Most likely moisture behind the rubber cover over the switch.Just pull the cover back dry with hairdryer then smear some vaseline over the terminal.If that fails replace the switch.
