Oil Sensor...How To?
eonan
I've got a question about the oil sensor (M900, but the principle is probably the same for many of the bikes).
A while ago now, I ripped out all the warning lights, sidestand switch etc and generally tidied everything away within the loom. Now though, I'm thinking I want to run an oil pressure warning light after all.
I have the oil pressure switch and I have a LED. So...what do I need to do in between?
TIA :D
Here's a circuit for you. You don't need to run a wire from the switch to earth because the body of the switch makes the earth connection.
Why didn't you ask me last night you numpty? :rolleyes: :)
I guess I was so happy and relieved you managed to fix my rear brake, it just kinda slipped my mind :D
Is there a prefered place to wire into on the switched circuit?
Where ever it's easiest. Probably from the back of the fuse box at the fuse for the brake lights/indicators or the one for the coils. That's if your bike still has a fusebox :rolleyes: :D
humm on the oil warning light front , ive cunningly (read perhaps stupidly) pluged the normal hole for the oil pressure sensor and have plumed one in on the out of the engine oil cooler line. is this wise ?
Old Triumphs had pressure gauges, when your boots got p!ss wet thru you knew the pressure had dropped. Ducatis don't need them as a light will be enough:)
