Oil pressure
Pict
Specifically, what operating pressure should oil cooler lines be made to? Am thinking it is just a little higher than 'not much'?
The workshop manual for a 888 (same cases and pump -assumes carbie SS engine) list max oil pressure as just over 11lbs/sq in. So not a lot at all. Though its still suprising how much it can leak if a seal is a bit off.
