When I was washing the bike at the weekend I noticed that it had an oil leak from the right hand side. Hmm! So, I whipped off the fairing panel for a better look and could see it was coming from under the oil pressure switch. I unscrewed it and put it back on with another crush washer but when I started the bike I could see it was leaking worse than ever
I got another crush washer and tried again - still leaking! I then tried tightening the switch a little more and this was the result
Now the torgue for the switch is supposed to 19Nm or 14 lbft, but I only ever nip it up and a little bit more. The spanner I use is only 4" long so I'd need to apply a hefty 42lb to the end of it just to get the switch up to the recommended torque. So I've no idea what caused the switch to fracture, it certainly wasn't overtorqueing it on my part, but I'm glad I caught it when I did. Imagine that coming apart at 80mph. The oil pressure to the crank would go to zero in an instant and it would empty the sump in seconds.
So the bike is off the road while I await a new switch arriving from DG. Rather expensive at £25, any car one I've ever replaced has been well under a tenner. A VW one will fit but the electrical connection is different.
