Noise when ignition turned on before start up.
Mozza
I've had my Multi 1200 s for two years now without any problems but in the last week it's started making a strange rattle! .When I turn the ignition on it makes the usual noise like its priming the fuel pump or something, but that is followed by a short rattle noise that lasts for just a second.It starts and runs fine.If I turn the ignition off and on again it doesn't happen again until its been stood a while.The noise seems to be coming from a black box with electrical wires going into it located in front and above the rear brake master cylinder. I'll be taking it in for servicing in about a month but I'm wondering if its serious enough to take it sooner or not.
The box in that location is the servo motor for the exhaust butterfly valve. If you still have the valve connected maybe the cable is sticking?
Hi Derek,
My multi has been decatted (before I bought it) so there is no cable or valve visible .Maybe its trying to work for some reason?.Not sure why it should suddenly start doing that though.
If the motor is still there, and I'm sure it will be unless it has been electronically bypassed, then it will still be trying to work either against a spring on the cable, which might be tucked away somewhere, or against some sort of weighted counterbalance.
Hi Derek,
I've had another look and I can see at the back of the exhaust servo motor there is just a hole where the cable should probably fit .I'm guessing that some sort of substitute for the cable has dropped out! . I will probably just leave it as it is for now as long as I get no problems and get some advice when I take it in for service. Thanks for your advice.
The cable normally attaches to a drum at the front of the servo motor (see attached pic from parts list) I've no idea what the back of the servo motor looks like, I'll have to have a look. If it's giving you no problems, getting it looked at when the bike gets serviced is a good idea.
Hi Derek,
Thanks for the pic it makes it clearer.I think the hole at the back must be a drain hole.Its really difficult to see the front. This morning on my way to work I got a warning message relating to the exhaust.Didn't get it on journey home.Might try and sort it but I think I will need to remove the servo.It doesn't look like a simple task.
Mozza.
Yes getting into isn't easy. After removing the seat and the side panels, the easiest way is to loosen the top subframe bolts and remove the bottom ones. This will allow the subframe to pivot backwards allowing easier access to the servo motor.
Thanks again Derek,I'll probably leave it for now as I'm going on holiday at weekend.will have a go at it when I get back.I have discovered that it doesn't have a drum type actuator but more a heavy looking lever.It seems to be operating OK(not loose) but not attached to anything.
Mozza.
Lever thing is possibly a mechanical contraption to make the motor think it still has a cable attached.
Something like this?
You can eliminate the motor altogether by pluging one of these into the harness.
http://www.vizi-tec.com/duc-ee/
Thanks guys ,that looks like a good option. I'm just monitoring things at the moment (no faults coming up today) . I've certainly got a much better understanding of the situation after everybody's help. Thanks again and I'll let you know how things turn out.
Mozza.
