Nightmare Brakes
abacus614
Morning all.
I've replaced the front brake lines on my 2001 750 for a Hel race set.
I've followed the Haynes manual on how to bleed the brakes and I have fluid coming out of both bleed nipples with no air. But I just have no pressure at the lever!
Any suggestions?
Try pumping the lever untill you get a feel to the brake and then cable tie the lever back leaving over night or for a period of time, this will disperse any air in the system. If you are getting a better brake go over the procedure again. Failing that replace the m/c piston and seals.
Sam
I seem to routinely take the calipers / master cylinder off the bike and make sure the air bubbles can travel directly up and out of the bleed / back into the reservoir
The most likely cause is there is still air in the system. It will end up at the highest point which is usually at the master cylinder banjo. Wrap a rag around the area and use the banjo to bleed it.
So am I right in thinking, slacken the banjo and pull the lever.
With the lever held in tighten the banjo and repeat until it gets firm?
I have got into the habit of back bleeding, from the calliper to the master cylinder, this is due to the fact I also have a Guzzi with the linked front left and rear callipers, they are a nightmare to bleed the normal way, and by back bleeding it's near enough instant.
I use a large syringe, ebay or the local vet!, with fluid in it attached to the nipple on the calliper by a length of tubing, put a wee bit of pressure on it and loosen the nipple, the fluid is then forced up to the reservoir expelling, hopefully, all the air. It can take a good bit of force to push it up, also make sure that all your paintwork is covered as it can squirt out of the reservoir. Finally tighten up the nipple.
Everyone will have their own method but this works for me.
Even with a vac pump once upon a time I ended up buying a banjo end bolt, for the master cylinder with a built-in bleed nipple - made life SO much easier...
Thanks for all of your replies
There's definitely no air in the system now and the new pads have moved towards the disc, however there is still no pressure.
I've spoken to Ducati and they reckon you can't rebuild the MC. They want £120 for a new one
One last thing. Did you push the calliper pistons all the way in before you started? This minimises the space behind the pistons, it should be next to nothing, and reduces the chances of air remaining in the callipers.
You can also try as Sam suggested; cable tieing the lever to bar and leaving overnight or longer. I had the same problem with my Pantah and in desperation tried it. I left it tied back for a couple of days and lo and behold I got pressure. I can't think of any physical reason why it should work, any air there can't get out and it can't just disappear but it did work. :dunno:
Would you leave the cover on the master cylinder if I were to try that?
Bleeding
Take the lever off which will allow the piston in Mc to move further back after you press with a screwdriver shaft. Sometimes dirt build up in the piston cylinder due to the rubber seal perishing causes limited piston movement which still allows the fluid to get out the nipples but no pressure. Use the screwdriver as the lever pushing in and out to bleed the system. This has worked many times for me when the system won't build up pressure. If it's going to work only a few presses is required and full brake achieved. Required on most occasions on Harley's and sometimes on my monster. It was the only way to bleed drag speciality mc fitted to custom choppers in the late 70s. Pain in arse.
Geoff
The theory I was told behind keeping the lever tight to the bar overnight is the pressure in the system forces the air back into the m/c.
Sam
Sam
And presumably when you release the lever it escapes back to the reservoir?
Geoff
An update. I tried the lever trick, I tie wrapped it to the bars for a good 24hrs and nothing.
Then I tried Geoff's trick and believe it or not it worked and now I have a nice firm movement within the lever. However considering that this is the master cylinder for the front brake should it be cause for concern going forward?
Mc fine
There's absolutely nothing wrong with your mc. Been doing this fix four 40 years on all sorts of bikes when same symptoms occur. If I ever meet you will explain why it works.
Geoff
