Multistrada Starter Motor
winston
My bike failed to start at work and now I have run a multimeter all over the starting system the starter motor has failed, electronically. The sidestand switch, starter relay, battery etc. are all functioning ok and I have full power right to the starter. However the meter is showing no resistance across the motor hence there is some kind of electrical gremlin inside. I am 'reasonably' nifty at this kind of thing so can anyone tell me if these things are serviceable once removed and if not where would be the best place to get a new/reconditioned one and what price (£200 ish ?). Any help would be much appreciated.
The starter motor windings are very low resistance and will read practically zero on a normal meter. Did you mean infinite resistance? New brushes can be got but I can't remember where from.
There was zero resistance Derek on any of the scales. An Auto-Electrician friend checked it for me afterwards and he confirmed it wasn't right. The meter was checked against an indicator bulb first. I'm going into work tomorrow morning to take the motor off. The voltage at the starter connection was good at 12.8v as it was at the relay. I suspect it may be the bushes or some loose connection/dirt as it was sudden. I have ridden it virtually every day in all weathers for two years now and it has 20,000 miles on the clock. It's nearly four years old.I bought it with only 2000 miles on the clock so I've done 18,000miles in under two years. I've changed the bushes on my washing/drying machines many times. I presume it will be same principle but smaller.
Just spent a couple of hours with the bike and I can't fathom how to get the motor off. There are two external hex bolts that I took out but the motor wouldn't budge even with gentle persuasion. Does anyone know whether or not there are any oither bolts holding the motor in place behind the left hand crank case as sat on the bike ?
As a slight aside when I tap the motor with a hammer with the ignition on the usual start-up whirring noises are heard. Then if I press the starter button it tries to start once but then disengages and there is no further electrical power until I tap again with hammer. This all suggests that there is something loose/worn/broken in the electrickery department of the the motor.
Martin
Sorry no guitar fixing/buying as yet. Washing machine, dryer, microwave and new kitchen base units (4 mucky kids) and bike problems have taken top priority. Everything seems to have happened at once. Was really tempted to go and buy a 1098s last night after the beer had got the better of me. The one where you pay half cash and the remainder at 1.9% over three years. I was searching high and low for a yellow one but they only seem to do the base model 1098 in yellow.
As far as I remember the external bolts just hold the the cover on. You will have to drain the motor and take the alternator cover off; there should be three allen bolts holding the starter motor in place.
you do have to drain the oil and coolant then reomve the generator cover, as Iain says there are three allen bolts holding it on, one or two from the inside.
Nothing wrong with the base model TBH. Mine's as quick as (and corners as well as) any S and you save enough money to spend on a HUGE amount of gas! :D
You're right Pete. It was just a mad thought after a few beers. I can hustle my Multi if needed. The drive out of corners is just right and so predictable in the wet. The 1098 base model would far, far exceed my capabilities. I'm going to wait until next spring first to see if there's a new Multi and/or a 1100 Monster. I sat on the 696 at Rivington Barn a few weeks ago and was impressed but I'd not taken my paper licence (only my card one) so they wouldn't let me test ride any of the bikes. Having said all that I do fancy a 1098 in yellow.
