Multistrada DVT bottom shock bush/bearing replacement
HootOwl
Well-known member
Ducati shock absorber bushes do seem to be a fairly common wear issue on some MST bikes
It took me ages to find the thread I knew I had seen that offered a replacement bottom bearing for the Multistrada's as Ducati do not supply them.
This is the bottom bearing that is good for the Sachs shock on the manual suspension type DVT's Shock Bearing Only - GE12PW - 12x26x16
No idea on the top mount, or whether its the same or not, but this is the common problem one.
It should be useful for anyone that may encounter the issue. The bearing number is GE12PW and the bush/bearing is 12x26x16mm
Plus as a novelty, its actually a thread on motorcycles on here :D :D What do I win ? ;)
You win AirCon's watch ⌚👍
