mulistrada speed wobble!
shane147
Just wondering my multi lately at higher speed 100mph plus seems to be getting a real wobble on seems to be coming from the fromt end,gives hell of weave on,for no apparent reason,checked all tyre pressures etc,everything torqued up correctly,any suspension setting that anybody could recommend to a possible cure folks,?
it depends upon your weight , the multi is a long travel bike which is set up for heavier riders/2up or luggage, if you are light it sits high in the suspension stroke and gets a bit of a vague feeling in fast sweepers, it doesn't go anywhere but it feels a bit weird if you are used to sport bikes. high position and big bars all catch the wind hich make it worse.
both of mine have done that and i just learnt to live with it :)
A few years ago i once changed the screen on a jap bike after that it had a profound weave at anything over 90. Just a thought.
tis a wide bar thing cos theyve got wide bars they amplify the problem but a click or too more rebound on the rear should help and maybe lessen the preload at the back too
