Hi folks, just finishing getting the bike (1000ss) back on the road for the summer. I removed the MPL clutch slave cylinder to fit a chain crankcase protector, & had it hanging down by the hydraulic line for a couple of months.
On re-fitting it, it went back on ok, but the clutch isn't working. I bought the mpl 2nd hand, & have no instructions, but just fitted it "as it came" last year & it worked fine. Looking inside it is totally black (unit is black), so can't see much.
Should there be a separate piston, or if the clutch lever has been pulled by accident during the time the mpl's been hanging loose would, 1) that stop it working, 2) not prevent it fitting, 3) need the piston pressed back......presumably in a vice?
Hoping to travel to carry on work today, so a quick answer would be great.
cheers
Gary
cheers
Gary
