Moving oil cooler
aircooled
I want to move the oil cooler on my 1992 750ss from where it catches all the crud from the front wheel, to above the horizontal cylinder as per the monster. I have all the pipe work to do the job, but i am unsure as to the best way to mount the cooler, it looks to me as if the original valve cover that holds the cooler at present will snag the rev counter cable if i use that? So will i need to buy a monster valve cover? or is there an alternative method of doing this (ie cheaper)
Cheers Frankie
Your gonna need a Monster cam cover mate. They off-set the cooler back into the midda (if you know what I mean) you can't just swap the lower and upper cam covers without your cooler becoming very offset.
...you could go down the route of what I did - I can't post another pic of my bike up here again otherwise I'll get barred, so you'll have to look in my gallery. But I've hung it on fabricated brackets from the mounting point of the original reg/rec (which is relocated). it sits alot higher - right between the forks and front mudguard so it's getting alot of fresh air!! :)
...as an addendum to the above, your lines may not be long enough for that mod. It does rather clean up the horizontal cylinder though (if you've got a half faired bike and Bevel cam covers!! :) )
If you do what Ed suggests with the original oil cooler it will clout the front mudguard on full bump - I tried it. You will need to a shallower oil cooler to fit in that location. Either that or fit it as you thought using a Monster upper valve cover.
i like what you have done with the oil cooler Ed your right it does tidy up the front of the bike, but for me at the moment the cost of new pipes and a new oil cooler is to much expense, so will go with the second best option of using a monster valve cover
thanks for the advice
Frankie
Frankie
Ok, thats fair enough. Now I have a spare one here if you want to make me a reasonable offer. They aren't mega bucks but you can have this one if you want - it's virutually new and only been fitted to my bike once! :)
Hi Ed i have sent you a PM about the rocker cover. I was going to use the original oil cooler, but when i checked for space i was a little concerned that the cooler would block the limited cool air getting to the rear cylinder, the Monster cooler is small do you think this could become a problem?
Thanks Frankie
I was told that you could run the motor without an oil cooler providing it wasn't being worked too hard or being used in hot climates.
If that is true then perhaps any oil cooler would be sufficient for most use.
Derek would confirm I'm sure. (Ed's spends most of it's life getting thrashed!;) :) )
For ordinary road use the Monster oil cooler will be fine but if you thrash the daylights out of it around a track then the bigger the better. Some US 900ss riders have retained the low mount oil cooler and fitted one above the horizontal head as well.
Remember Frankie that the first 750ss didn't have an oil cooler. You won't upset the cooling of the rear cylinder fitting it above the horizontal cylinder.
Yes Mine does spend alot of its time up in the upper regions of it's rev range. With High compression pistons this leads to higher crankcase pressures + alot of heat which = loss of efficient piston-ring tension which = alot of oil consumption which = alot of cooling required = big cooling better crankcase breathing (which I've sorted)
Your 748 cc motor is a different animal compared to the lumpy, low-reving 904cc motor, much nicer in my opinion! :)
If I'd made my Imola with a 750 motor fitted from the outset and knowing I'd move to the Highlands within 2 years of building it, :rolleyes: :p - I would have left the oil cooler out, coz it certainly clutters up the front of the bike! I also toyed with the idea if registering it for daytime use only, omitting the front headlight and fitting a large oil cooler where the headlamp would normally sit utilising a 'holy' fairing much like the original works bikes. :)
Answered your PM by the way. :)
