More Ducati parts interchangeability?
Dukess1999
IMO it's a big risk buying something like this with no provenance, I think he would be lucky to get that for the whole engine
Well the crank will fit but !
I can't find the length of the OEM rods in the workshop manual, but from his own description he infers they will need to be 6mm shorter than the SS one so that the pistons maintain the same heights. If you have to source shorter aftermarket rods to make it work it's not worth it. Not at £400 for an SS crank !!
I've given this some further thought. Now the 916 stroke is 66mm and the conrod length is 124mm. If a 68mm stroke crank is fitted then the piston will still be 2mm higher at the top of the stroke. So you either need rods that are 2mm shorter than stock or you have to space the barrel up to maintain the 1mm squish required.
I wasn't thinking clearly enough yesterday :doh:
If the stroke is 2mm longer, then the piston will rise 1mm higher at the top of the stroke and 1mm lower at the bottom of the stroke :o
So there is only 1mm extra height to loose. That's the same as the normal squish distance so it could probably be accomodated with extra gaskets. I wouldn't like to get it wrong though :eek:
