Indicator Lights and Indicator Warning Light
Good Morning Derek!! The bulb has arrived only took a week from HK so not bad. I will go and fit it this afternoon, I had to buy two bulbs so I have a spare.:comp2:
It hasn't worked! Indicators still work even when the bulb is take out. I think the diodes are the reason the warning light ain't working. So I think I will have to take a feed from each indicator and have a seperate Led bulb on the clock top.
I am going to get the monster MOT'd and I spoke to Howard the MOT man and he says that the warning lamp should be working or it will fail. If he can see the indicators flashing whilst on the bike that will be good enough for him and that will not fail the test, Excellent! Sorted! Result!
Oh Bugger! Are you sure the diodes are the right way round?
I see from you're next post that you managed to get the Mot though. :thumbs:
Well I wired it as per your circuit diagram, I could always try one the other way round to see what would happen? I would have thought the diode is doing it's job as intended because the indicators are now working, whereas before I put them in all four were flashing like hazards do. If I wired both of them to earth as well would that make any difference or just blow the fuse!?It's booked in tomorrow and I have spoken to Mot Howard and he says the tell-tale is part of the mot, if there is a light it should work. He wants me to have another go and see if I can get it working before I take it in!
I just looked at the diagram I sent you and can't see why it shouldn't work. The bulb should have one side to earth and the other to the junction of the 2 diodes which should be face to face. i.e. the ends with the white stripe should be together.
Are you still using a filament bulb or an LED one? LED bulbs are polarity sensitive and will only work one way round. If it's an LED wedge, try turning it round.
Don't wire the diodes to earth, you will certainly blow them if not the fuse. The only connection to earth should be through the bulb (or LED).
Hope this is useful.
If, as your Mot man says, you do not need a warning tell-tale as long as you can see the indicators but if there is one it must work (bit of a Catch 22 that) can you tape over the warning light so that it no longer available?
I will try the tape one if nothing else works!
The only thing I can think of is that there are only two wires and one comes from the right and the other from the left indicator I didnt trace it any further down and just put the diodes on the ends where the wires came out of the bulb. There isnt an earth wire on the holder that the bulb uses. Well not that I could see.
That's your answer Steve. There is no earth.
Originally each of the two wires went to the bulb holder so that the bulb was wired across both sides of the indicator circuit. When the left indicators were on it would earth through the right hand indicator bulbs and vice versa.
You need to join the diodes face to face as I described. Take that junction of the 2 diodes to one side of the warning light bulb and earth the other side.
Does that make sense to you?
Yes I have got it, so the rings on the diode want to be nearest to each other rather than further away from each other and joined to one wire while the other with no diode is earthed?
Yes.
I did send you a diagram :rolleyes:
Typical, I had chucked the circuit diagram out, so I went back and undid all the dash unit and first off one of the wires had broken but as the indicators were all still flashing I figured I had cocked it up and so I soldered the two diodes together and then to the coloured wire and the black wire I soldered a longer bit to and set the indicators going and touched the black wire to the headlamp rim and guess what? the 'effin light on the dash was FLASHING hey what, 'effin brilliant! So I soldered the end to the earth coming out of the lights 'on' light and I am using the original bulb too. It only took me about 30 mins to get it sorted but took nearly an hour to get it all back together because there are so many wires in the back they all get in the way of the screwthreads on the instruments and the bank of tell-tale lights. anyway it's done it will pass the MOT and were all happy!
Thank you very much for helping me out,for the diodes and persevering with me and having the patience of a saint!
Thanks goodness for that! Good top hear a happy rnding. You're the one who's persevered Steve, well done. You can buy me a virtual pint for that :)
