How much of a problem?
silverburn
...is coolant seeping from here:
In case this wasn't obvious, this is the nearside/left-hand view of the engine. It's a Diavel, but I suspect the design is identical to most recent Duke engines.
Note: it only seems to seep when the engine is cold. Once it's heat soaked, it doesn't.
What's the fix? Is there a gasket under there that needs replaced?
*Edit* Yeah, yeah...sponges...soap...etc etc
If that is indeed coolant it can only be leaking from the water pump which is under the black cover immediately above the central cover, perhaps running round the edge of it and then downwards at the lowest point. The cover in the middle keeps in oil and has an O-ring to seal it. The water pump cover has a gasket. I'd check the tightness of it's screws first. If they are OK best to take the bike to your dealer as I assume it is still under warranty.
ok, I've done a quick run round with the allen key, and the one closest to the centre cap was loosest. And by loose I mean it was still pretty tight - only took a wee pinch 1/4 turn to tweak it up to "bloody tight".
It's in to ERS shortly for the winter prep and trip to Switzerland - think I'll get Eddie to do it under warranty.
Ok, that tiny tweak might have solved it - no coolant visible this morning, and it's remained bone-dry for the entire ride to work.
I wonder if I might get the gasket replaced anyway, as a precaution.
