High idle when hot
sprogg
Just replaced throttle bodies with second hand set. Bike runs smoother but now idles at 2K + after a 30 mile run. Will it just require a carb tune or is it more technical? Wanted to ask before removing all the fairings yet again.
Thanks in advance :D
It sounds ok. Idle normal until hot then it sticks at over 2k. Stupidly didn't balance the throttle bodies before putting fairings back on. Just wanted some feedback as I can balance throttle bodies but anymore will involve taking bike to specialist.
Recommend you do a complete throttle body set up.
Check out bikeboy.com for details.
