i just bought another duke but this time its a 999s with ohlins can any 1 help me to set it up right`ish for me i`m 5ft 9in and a bit chubby 15 1/2 stone any info thanks
Piccies now appear to be available.
Not that I ever would, but, if you can get to that archive page it should be possible to use the File>Save As option in your browser and save a copy of the page on your hard drive - purely for reference.
Seeing as it is htm page it should create a new folder for the files and details where you need it.
ride height 285mm, probably about a 90 spring rear and 10.5 maybe 11 front as a start point but you do need to go somewhere who knows what they are doing. With stock spring and 15 1/2 stone on board the bike will not want to go around corners, i assume its a mono S which should have a 70 rear as standard, ( bips get a 75).
i added most of the old Section 8 article here it also has a guide for ohlins spring codes.
depending upon type of riding you'll want about 30mm loaded sag front 30mm rear.
