Help identify stray part
johnclat
Hi,
Whenever I google anything Ducati, I hit threads in this forum and there's always good advice. So I've finally joined the forum and I'm hoping that someone might know ST's well enough to identify a part for me.
I've done quit a bit of work on my bike over the past couple of months and recently found this part lying on the floor next to the front wheel. I haven't seen it before and don't have a clue where it might have fallen out from.
I'd be grateful if someone out there can help!
Thanks
I've had my ST4s well stripped down plenty times but I can't remember seeing anything quite like that, it looks like a rod or a screw should go through that hole. The throttle body linkage has an adjustable rod and ball-joint but it's nothing like that.
Not an expert on the ST but not seen anything like it on my SS and MTS.
Could it have been picked up off the road and got stuck in your tyre tread?
Hey DavidW, that's a thought!! I've been pretty careful and I'm not usually the type to have left over bits when working on something so I've been quite flumoxed by this bit.
Pict, the steel rule is old...don't remember where it picked up the white spots :)
i think its from inside the mirror stem , broken previously maybe and fell inside fairing then dropped out when you stopped
