Handling problem
Steviec
Need advice on suspension with my 1098r. I know the first answer will be ERS & I will b taking it there . The problem seems to b with the front doesn't like changing direction quickly & it shakes when hands taken from bars at slow speed.any ideas would b greatly appreciated
Thanks
Steve :confused::confused::confused:
Depends how heavily it lands on the front wheel after some hard exceleration :D
Not necessarily failed - maybe just loose or notchy.
Motorcycle Performance Glasgow - book well in advance and get your bike fixed by Stewart Miller.
Suspension is a science! Stewart is the best, and I've used a few to set up my bikes in the past.
Contact him well in advance, he's not around much these days as he is spannering for Scott Redding in Moto2.
I have no association, other than being an absolutely delighted customer :thumbs:
You'll find him next to Ducat Glasgow, and he's listed on their website.
Thanks
needs more info to be honnest;
is the set up totally stock or partly modified?
are the forks lowered or raised through the top yoke?
headshake can be (lack off) rear damping (compression and rebound)
Your arms are acting as low frequency steering dampers, so dont be suprised when the feel changes when you remove your mits!
sounds like youll need to balance of the rear and front suspension
they need to compress and rebound at the same rate
to check this get a mate to push down on the tank and watch the suspension compress and then rebound at the front and back...should be about the same rate..
adjust compression and rebound approptiately front and back..
im assuming theres oil in the front forks.
another thing to check is that your using all your travel on the forks properly..
tie a tie wrap round the fork stantion and head out for a run ..once your finished check to see how far done the fork has pushed the tie wrap..
if its all the way down it means your using the whole travel of the forks..which is what you want
if its not adjust the compression accordingly..
im no expert but worth a try before you visit the suspension guys
all the above works a treat on my race bike
Front end totally standard & have never had bars shake on any other bike I've owned
Set up standard
I had my 1198 set up at ERS on Saturday the difference in handling is like night and day.
Well worth it !
How was bike handling before set up ????
Just got used to it.
It wanted to run wide when you got on the power, bounced you out of the seat and liked to wheelie if you gave it a handful.
It powers through corners and feels a lot smoother over bumpy roads now.
Dont want to get off it now !!!
Sounds like how mines is at moment cheers del:)
I'm no suspension expert but these are the characteristics of too soft compression damping at the rear possibly combined with too hard rebound compression, also at the rear. The bike squats when you accelerate out of corners causing it to run wide. It also increases the tendency to wheelie.
Have a look at this suspension set up guide.
All of the above are good suggestions and definitely worth looking into but before you go touching the suspension I would check the simplest and cheapest first. It's very unlikely the suspension will have moved of its own accord (assuming no one has been mucking with it which is not unheard of)
As Anteater suggest, tyre pressures. You would be amazed how many customers call us with "handling issues" at the beginning of the season and they have completely forgotten about this.
Next, you might just have a badly worn tyre. I know that is also unlikely at roughly 60% of it's normal life but it really depends on how you ride, it's worth checking. I would be willing to bet it is either a worn tyre or the wheel has thrown a balance weight. A new tyre would fix both of these.
As to the set up of the bike in general. We normally find they are hard at the rear & softish at the front which seems more so, because the brakes are so incredibly strong.
If the rear is too hard, it causes the bike to "pivot" around the rear axle under very hard acceleration - in other words wheelie. Softening the preload on the spring helps the bike squat instead.
The running wide can be caused by not enough ride height at the rear and also too little rebound damping on the front, this causes the forks to spring back too quickly, lifting the front and changing the geometry as you tap the gas. Slowing this down will help the bike from pushing wide.
I've been through loads of different set up changes on my 1098R over the years.
Most dramatically felt improvements on bike suspension are done with geometry first and dampening as the final adjustment to tweak.
But as a rule, try simple first.
Mart
Thanks for that advice Martin tyres & pressures are good will soften rear preload as rear is quite hard hopefully get it sorted without too much hassle thanks again
Steve :cool:
the other one to look at is where the chain eccentric is set, as Martin says ride height affects squat/anti squat because of relationship between drive sprocket, rear sprocket and where pivot is in relation to them, on a single sider you really need to alter the ride height when you adjust the chain, in the "old" 916/996 days datum tools were common yet i hardly see them mentioned on the 1098/1198 setup advice.
Initially i'd suggest getting the right spring rate, you cant do much if you've got the wrong weight spring in as preload is a geometry adjustment not suspension, it affects ride height not how firm the bike is, once you get right spring then do sag/preload and ride height rod and only then mess with compression/rebound. On the throttle do a great dvd on how to set up Ohlins, well worth a buy if you want to understand what is going on but I'd always suggest going to a good tuner first just to get springs sorted as you cant fix that by twiddling knobs.
:lol2:Big thanks to all who gave useful advice .
Adjusted rear preload and what a difference no more head shake & she actually turns in now . Some more fine tweaking needed but far superior to what I had .
Thanks again guys :D:D:D
So it was nothing to do with riding about on one wheel then Stevie ?..........:D:D
;)Oh is that what the front wheel is for turning !! Cheers kenny you getting out for run any time soon :lol2:
Hey Stevie ,
How you keepin ?.
Was wanting to give you a bell for Sunday as the run you were going on sounded good.
couldn,t commit to it though as i had friends up and ended up hungover on Sunday mornin .
Managed to get out about 3pm once i was feeling up to it - was at the Welly about 4.30 then doon the road through Inverary.
Yeah sound kenny
We passed welly about that time you must have been there as there were quite a few Ducati in at that time
Hopefully catch you out & about soon mate
All the best
Stevie :flash:
:thanks4:had bike down to ERS on Friday before heading to northwest
All I can say is thank you eddie it's a different bike even in the wet a joy to ride bring on some dry days:D:D:D
