Rebuilding engine and I have got the cases together. Attempting to adjust the arm for the gears inside the sides cases where it rotates the drum, not the foot lever. Im struggling to get all the gears to select, any ideas?
There is an eccentric adjuster on the bit the holds the return spring. Loosen the nut and rotate the screw so that the claws on the selector pawl are equidistant from the pins on the selector drum. I can't remember if the gearbox should be in neutral or 2nd.
Ok Derek, I have read elsewhere its neutral. It was selecting three gears ok but then not pulling the drum round enough for the rest.....will persevere
You need to adjust the eccentric (3) so that the lever (1) is central within the stop plate (2) View attachment 11157View attachment 11156
Then tighten the nut (4). The stop plate is the bit behind the lever with the eccentric.
After you have done this postion the selector assembly so that the claws on the selector pawl are equally distant from the pins on the selector. View attachment 11160
