Fuel warning light Monster 1998
sam
Good Morning folks,
Ran oot of petrol last night 140mls to a full tank , thought that was poor! (maybe need to start driving it instead of thrashing it)
Anyway, Im sure you posted this before Derek but cant find the post, what is the likely cause of this to fail ( excluding a blown bulb )
Sam
Most likely the sensor in the tank. It is on the same circuit as the horn, indicators, brake lights and neutral switch. So if they're working OK then there is most likely power getting there. When the fuel level drops far enough the sensor closes (it's just a float switch really) and sends power to the warning light which should light up. If the bulb is OK bridging the Blue/Black and White/Brown wires at the tank should make it light up. If it does you know the sensor must be faulty.
At least you know how far you'll get to tank now :D Fill up at 120 - 130 miles in future and you won't get caught out again.
Cheers Derek,
Have you had a sensor to pieces yet, is this a repairable unit ?
Sam
I had a look at one in a SS tank I have there are two wires attached to something inside the tank. Back later lightning storm happening.
The SS has 4 wires going through the gland in the bottom of the tank. As well as the fuel level sensor there is a supply and ground for the fuel pump. If it fits (it probably won't) you could just leave the other 2 wires disconnected.
Yipee, fixed the fuel warning light I had plugged the socket into the sidestand socket. :censored: :lol2: I had issues this evening with banging in the exhaust at low revs so had the tank up checking electrical connections and thought I may as well bridge the warning light socket to make sure everything was working and eliminate the sensor.
The warning light illuminated when I bridged the wires I then bridged the open socket which I thought was for the sidestand switch but when I built the bike I had obviousley connected it to the wrong socket. Ah well!
We all do daft things like that now and again. At least you've learnt something about your bike :)
Changed plugs misfire still there, changed igniter box no different changed coil same, feck had just changed the oil 50mls ago now it looks likely to be the pickup causing the problem !!! :mad:
