Fuel sensor - repairs
Duke of Prunes
Well-known member
I don't know diddly about the newer models , but this might help in general .....
.... or it may be completely useless info ...... :rolleyes:
On the 748 , 916 , 996 era bikes , the fuel sensor has a float that slides up and down a strip of circuit board .
The board has two lengths of Nichrome wire and the float has a pair of contacts that bridge ( or short )
across the two wires .... so it is effectively a potentiometer ( or variable resistor ) .
Main causes of failure are :-
(a) the float is stuck , or won't slide freely
(b) the contacts on the float are coated in crud and not making good contact with the wires
(c) the wires themselves are coated in crud
To repair :-
The bottom flange has to be removed from the tank , and the tube that contains these workings
needs to be released from the two Terry clips that hold it in place ....
..... which can be really awkward !
Once removed and dismantled , clean up the wire and contacts ..... fine wet-and-dry , scotchbrite ?
.... it's your choice .
Notes -
it's best to have a new flange O ring handy ( ~ £10 as a Ducati part , but only 89 pence elsewhere ! )
Before refitting , use a multimeter set to Ohms ( low resistance scale ) and check for smooth changes
in resistance as you move the float up and down .
Option B -
..... pay silly pounds and 95 pence , for a complete replacement fuel sensor unit , from Ducati .
To repair :-
Notes -
Option B -
Pictures next time around someone.... good bit of help that.
Yes , I agree ..... detailed pics are a great help .
If anyone has this problem in future , and drops on to this thread .... please post some pics !
(y)
I usually take pics as I'm working , and I did a big overhaul on the tank last year
.... it was a horror story in there , trust me !
Most of the pics I have are connected with the shocking state of the tubes , the pump and the filter basket .
Sorry , but this is all I could find ..... you can just about see the strip of circuit board I was talking about , inside the fuel sensor tube
Has anyone had any luck with finding a PCB replacement? My 1000ds 2003 had issues with the float and I am looking to replace the PCB altogether
