Gordon,
I saw this post yesterday and should have replied earlier, sorry.
The sender in the tank is an aluminium cylinder that's wedged vertically in the tank with a rubber buffer on each end to hold it there. The multi connector under the tank has 4 wires:- Brown/White and Black are the Fuel pump supply and earth, Grey/Black and White are from the fuel level sender.
The Grey/Black is the earth for the sender and the dash display. The White is the sender output and becomes Green/Black when it reaches the other side of the big multi-connector under the LH side of the top fairing (in typical Ducati fashion
). It then continues on to provide the fuel level signal to the LCD display.
The voltage on the White cable (or Green/Black depending on what end you are looking at) should vary between12v and 0V depending on how much fuel is in the tank. Presumably 12V for full and 0V for empty. I don't think it drives the fuel warning light directly, but logic in the LCD turns on the warning light when the voltage gets down to a certain level, usually one bar remaining.
If the sender was disconnected I suspect it would read permanently full but I might be wrong about that so check the connector under the tank anyway. A more likely culprit is the big multi-connector under the LH fairing, below the relays. These are notorious for getting water in with subsequent corrosion of the terminals resulting in all sorts of electrical mayhem. So well worth checking anyway.
If all is apparently well electrically then it may simply be that the float has stuck and maybe removing the sender and giving it a shake will get it free.
Access is via the fuel pump flange under the tank. So if you haven't changed the filter for a while you should do that at the same time and remember to get another O-ring for the flange before you start, these often swell with petrol and can be difficult to get back in again without pinching them.
In the meantime remember to set the trip every time you fill up and if you keep topping up by 150 miles or so you'll be OK.
Good luck.
