Fuel regulator o ring seals
Paulm2930
I’m struggling to find a part number for a replacement o ring seal for the fuel pressure regulator on the fuel pump flange. Can anyone help?
I'm sure I've seen wcp referrence an o ring kit for various events such as this???
@Nelly
I may have explained incorrectly as I have received an o ring under the part number you supplied but appears too big. Not sure if there’s an o ring where the red arrow is on my attached image. The o ring required is located in the flange where the white plastic base of the regular assembly inserts into. The o ring is about 1/2 inch across.
Does this look about the right size?
6mm ID with a 4mm Cross section... giving an OD of 14mm
The fitted O-Ring measures nearer 14.5mm OD but I can't take one off without damaging it as they are a very tight fit.
