Fuel Pump issue, 907ie.
ShedBob
I've been recommissioning my 907 over the past few weeks. Off the road for 8 years, running well when put away.
Today I finally got the tank back on after fitting a new filter but when I switch on the ignition the fuel pump doesn't spin up. The relays at the front click & I get an initial spark at the plug on switch on but no fuel pump noise or sparking when cranking.
Swapping the relays makes no difference.
With a meter I get 12v initially on the pump feed, then there is a click from the relay & the power switches off.
If I feed 12v directly from the battery into the pump I get a couple of strangled sounding gargles but it doesn't spin as I'd expect.
All the other electrics work. New battery.
So my thinking is that either :-
The pump's goosed after it's hibernation & the ecu somehow senses this & kills the live feed.
Or the ECU switches off the power for reasons unspecified because the ECU's goosed.
Or I've done something wrong.
Your helpful suggestions would be welcome.
Robbie
I know it's unlikely but is the kill switch in the RUN position? If it's at OFF the starter cranks but you get no fuel pump nor sparks. Of the 2 relays, one turns on the ECU which in turn switches on the other relay that energises the fuel pump and coils. If they are both clicking it's not likely to be an ECU fault. If only one clicks then it must be the ECU relay, so the fuel pump relay is either faulty or the ECU is faulty.
It could be that the pump has stalled after being unused for a long time but I wouldn't expect that to cause the ECU to switch off. At switch on you should get 12V from the relay for approx 5 secs then the ECU switches it off. This is normal. The ECU will switch it on again when (if?) the engine starts.
If you need me to investigate what happens on mine for a comparison I can do it easily just now because I have the fairings off for servicing. Changing the fuel filter was a bugger I wouldn't fancy having to take the pump out :ohwell:
Played with the kill switch & got satisfying clicks from the relays. The battery light dims in the off position too, I assume yours is the same.
I also swapped the relays over as they appear identical. No joy.
I'm thinking that if the 5 second power up/down is normal hopefully the ecu is ok.
There appears to be no pressure sensor on the fuel rail so I guess the ecu knows the engine is running from the 2 sensors on the left crankcase. Which is which ? I'm guessing they tell the brain the crank is rotating so turn the ignition & pump back on.
I should say I don't even get an initial buzz from the pump for the first 5 secs.
To think I was about to book an MOT too.
Yes, the battery light on mine dims in the OFF position too. :dunno:
There is no pressure sensor and as you've guessed the ECU knows the engine is turning (not necessarily firing) from the crank sensors.
Try connecting a bulb across the purple and black wires at the tank connector. If it lights up for 5 secs or so at switch on the trouble is inside the tank :eek:
I stuck the probe from my wee digimeter into the back of the feed into the tank. Got 12 point something volts for a few seconds then it switched off.....
Logically I'm leaning towards pump death. Just changed the in tank filter this morning, that was awkward enough.
Wish me luck !
Wish me luck !
Rather you than me!
Hi Robbie
I know the filter is directional, wrong way, internal valve can you blow through worth a check before taking the pump out.
Did you leave the tank without fuel for all that time ie no lube.
Just ma thoughts
Scott
Scott, I have a filter in the garage. It's the same as on any other injected Ducati and although it is directional there is no valve in it. I can blow through it just as easily in any direction. I think it's most likely that the pump has stuck through being dry.
Popped the new filter in the same way round as the old one. I think I agree with Derek & suspect the pump's seized through old/no fuel.
Been in Glasgow today anyway. Will try & get an hour or so at it tomorrow morning.
There are plenty Walbro ones on eBay if you can make them fit. Is the pump held in by those bolts away down in the bottom of the tank or does it just push into the holder?
This Bosch one looks very similar but is expensive!
I used a car one on my 851 ,Mazda rings a bell, it was peanuts £££ in comparison.
Do a search on the 851/888 forum , if I mind when I get home tonight I'll see if I can find the info.
Thanks chaps.
I've ordered one from Merlin Motorsport. Not exactly the same as the Weber one's no longer made. But not far off.
I considered using a generic one but didn't know enough about what was required so let my impatience get the better of me again.
Hopefully here for the weekend.
@Derek. The white plastic ring you can see around the pump bolts onto the rubber collar which the pump sits in. There are 2 tangs either side of the plastic which clip into the mount on the bottom of the tank. It's not too bad to get out once you've removed the filter & the "degasateur".
@Jim. I have no intention of chucking the old one away. In fact I was going to have a go at it today when the postie delivered the replacement today. I only ordered it yesterday lunchtime from Merlin Motorsport. It's a bit narrower but comes with 2 rubber sleeves & a slightly different gauze. Put both sleeves on & it sits within the collar fairly snugly. New gauze is a funny shape but can be waggled into place. The connectors are spades too so you have to adapt the wiring. Did all this, put some petrol in.
And it wouldn't go. No sparks or injector action.
Deep gloom. Sure ECU must be goosed. Had a guddle about & spotted that I'd mixed up the wires from the crank sensor & the cam sensor. Tried it again.
And away it went !
That's a good feeling eh ?
