Flaky engine paint
posiden
Well-known member
Just stripped the 749 down for its pre winter clean and I was shocked to see a lot of the paint on the lower of the engine is flaking off. The paint is also flaking off on the top of the engine where there are any hollows where water sits after its been washed.
The bike has hardly seen a wet day since I bought it in March 04 (7K on the clock) and I have looked after it really well - so why is the paint falling off ?
Is this common ?
Whats the best paint to use to cover it back up.
quite common and it because its rubbish
i used silver hammerite thats rubbish an all
though not too bad a colour match
Pete,
Same thing happened to mine and i got new engine cases through the extra years warranty I had. TBH its probably not worth the hassle and a wire brush and a repaint is all thats required. Geoff on here did his, maybe he could fill you in more on whats required.
Yep - common problem although the Multi hasn't seemed to have suffered. My 749 went back just before the warranty expired and had new crankcases :)
Flaky Duke
B#gger, wish id seen it earlier. At least the fairing covers it up. Hope the KTM doesnt look like that in a year or two.
If I buy an 848 will that do the same?
Im going to have a word with me old mate Casey and see if he can sort out the paint.
Engine paint
Hi,
Try RS motorbike paints. They do suitable primers, paint and lacquer with a maximum operating temperature up to 200 centigrade which is fine for engines - not barrels or head. I clean up the area with a dremel and a wire brush attachment. Get it nice a shiny removing as much oxide as possible. This helps the acid etchant primer bond to the metal. I have access to an air brush and compressor otherwise buy rattle cans. You mentioned water collection - I always ensure I dry any engine area where water can collect. Ideally use a compressor to blow of the water otherwise a water absorbent towel also works well.
I have monster and have recently bought a Tricolore. My first fully faired bike and I'm amazed at how much crap builds up under the protection of the fairings?? I always make a point of cleaning the deep sump area once the bike has cooled - you'd be amazed at the build up of rubbish even on dry day out. Especially driven down road with lots of farms in the area.
Geoff
...They do suitable primers, paint and lacquer with a maximum operating temperature up to 200 centigrade which is fine for engines - not barrels or head.
I'd be a bit worried if the head and barrels on my water-cooled bike were exceeding 200C :eek:. Are you not thinking of the air-cooled bikes Geoff?
Paint
Hi Derek,
I'm only generalising - apart from my Tricolore I've only ever had air cooled bikes for thirty years. I'd still be wary of using the paint on barrels/head especially around the exhaust ports. In the case of lacquers the more gloss they have the more susceptable to high temperatures which makes them yellow very quickly especially if applied thickly.
Geoff
True enough. Although I suspect that the crankcase on an air-cooled engine may get as hot or even hotter than the head and barrels of a water-cooled engine.
The oil temperature on my SS was usually just over 100C and sometimes up to 120C. Whereas the ST4s water temperature is normally around 69/70C with the occasional excursion up to 110C or so in heavy traffic. I realise the external surfaces of the motor will vary a bit from these but it should give a rough idea of what to expect.
Temp profile
Hi Derek,
Before anyone says ain't I sad!!.
Several years ago when the paint started flaking off I decided to measure the temperature profile of my engine to aid my choice of paint - I was bored! I attached several thermocouples to the engine and then using a data logger recorded the profile. Not content with that I then entered all values into a piece of software I was using for FEA (Final Element Analysis) on a vacuum vessel project. Anyway in the end it highlighted the oil temperature as viewed is a good representation of crankcase temperature. When trying to attach the adhesive backed thermocouples to the barrel/head they kept falling off so I was less convinced with my measurements there. The temp profile obviously varies depending on contact areas i.e heatsinking - frame etc where it drops off.
In the end I was happy with my choice of RS paint.
Geoff
Geoff
Techies like you and Derek that keep us on the straight and narrow!;) :)
I check the temperature on the casings by licking my fingers and tapping the alloy.........normal range is "ouch" to "B******d!". If at the higher end of the scale I reckon she is running a bit lean. :o
The bottom line says it all Geoff - that you were happy with your choice of RS paint. I wish I had access to all that test equipment and software though ;)
I can relate to that Stewart :D
