Roadrunner
Hi there all
Only recently become the owner of a 2004 749s, which I've been using for general pottering about.
Just a few things that I'm getting a bit miffed about.
1. Engine has a tendancy to stall when sitting at the lights, either with clutch pulled in or out. Have to give it a light bit of throttle and it's okay.
2. clock has a tendancy to revert to zero when bike is left overnight. Think battery may need a blast or becoming weak.
3. Also...anyone know factory suspension settings. gonna get back to standard and start again..
4. Throttle cables are being pulled when you turn bars to the right, so you end up revving the B@ll@cks off it. Not good early in the morning when turning it around on the drive.
Any help much appreciated.
K
K
