engine paint
Hi Brian
I promised Mike ( Hindsight) ages ago that I would look out what I used. Hang on 15 mins...
Simoniz Aluminium Engine Enamel
Primed with U-Pol Acid #8. I used this on the crankcases which were left complete so I couldn't bake. I think the garage was too cold when I applied it and the finish was a bit dry / dusty. And soft. When the engine was first run it got softer, but when it cooled its good and hard now. Thank goodness! Jury still out.
PJ1 Fast Black Satin Black 500F / 260C Engine and Case Paint
Applied straight to barrels and baked in the oven. Braw stuff.
Hycote Engine Enamel Aluminium
Primed with U-Pol Acid #8. Used this on the heads and baked in the oven. Nice finish, really hard. If I was doing the job again, this is what I would use.
I also used E-Tech XHT Graphite paint for the rocker covers and other bits. Again used over Acid #8 and baked. Goes on thinner than the Hycote but that suits the smaller parts. Again a really hard, durable looking finish once baked. Available in silver, it might be worth a try for the 'cases.
Marvellous, thanks fella.
Have started paintstripping, and just taken delivery of a pallet of dremel wire brushes :-)
M.
