Electrical problem, help please
NZ Monster
I've got a 2003 S4R Monster which I've recently rebuilt. It now refuses to start, when I turn the ignition the ignition lights come on, fuel pump makes a noise and the speedo indicates 100km/h (not the most exciting 100km/h I've ever done while parked inside my workshop) and that's it. The bike doesn't have an alarm. Anyone got a clue what's going on?
Does the starter click at all ? Could the battery be flat ? Have you checked ALL the fuses, been methodical at going around all connections, if you have rebuilt the bike you sound like you will know what is where etc.
There is an electrical hero on here who will no doubt be along soon !
Why did you rebuild it?
Was there a part of the electrickery system that was damaged or that you modified when it was in bits?
Like Ian says above, the electrickery wizard should be along shortly with his magic ducati branch if required.
Most of all - don't stress about it, it'll no doubt be something simple and it'll be quickly forgotten once you sling your leg over and go for that first blast.
Nice to see you here btw, and hope things get sorted asap!
The trouble here is where to start!
I don't know why you took the bike to bits but you obviously haven't got it back together right.
If I'm right, your bike also has an immobiliser linked to the instruments and ECU to further complicate things.
You say that the fuel pump makes a noise and the ign light comes on - well that's a good sign. But the speedo reads 110km/h right away - that's not such a good sign. First thoughts are that there is an earth connection adrift.
Does any thing else work? Lights? Horn?
Go over all the connectors and mke sure that they are fully home and fitteed correctly. It my be that 2 plug/socket assemblies have got their bits swapped around. Make sure that there are no wires left adrift. Are all earth connections making good contact - often an earth tag is bolted to the frame and the paint prevents it from making contact.
Let me know how you get on.
Good luck :thumbs:
Is the main live feed to the solenoid connected / clean? Is the solenoid clicking / sticking? (Kill switch? Ahem..!)
Mine wouldn't start sometimes and I found that the wire/plug that goes into the solenoid was a bad connection and I had to cable tie it on to improve the connection.
Fixed
Made sure battery was fully charged, checked every earth point and every connector. The left indicator now flashes permanently and I'm going faster 120kmph (still without the engine running!). Checked the battery and discovered that it's only giving 10.3v. Removed it and connected the battery from my truck and success. Obviously the compuetr is very sensitive to battery voltage!
Thanks for your help.:D
Funny things happen when the battery isn't up to scratch. Yet it's always the last thing we think to check. ;)
