Hi, looking to see if anyone knows if this will work.
I have a Multistrada 1100S with a duff ECU, does anyone know if an ECU from the US of A will work ok?
It doesn't matter where it comes from as long as it is the correct ECU. The MTS1100 should have a Marelli IAW5AM ECU and the appropriate hardware / firmware which is on the label should be the same on the replacement.
You should check that the ECU is virgin, if it has been previously used it will be coded to the dash and keys of the donor machine. Ducati Performance ECUs can usually be changed to other bikes.
Or you can buy an ECU of the same type and have it re-flashed with the map for your bike and with the immobiliser function removed so that it will work with your keys and dash.
Thanks for the reply.
American ECU's don't have immobilizer, so it won't matter that it's been used. What i'm trying to establish is if it will run on a UK wiring loom, or is it wired differently.
When I bought my ST3 within an hour I discovered it had an ECU repair bodge, I checked various forums and also discovered the gent I bought it from had been online on a Ducati forum saying he had tried to connect his laptop to his ECU and fried it, it seems he had bought cables that were faulty and had the + and - reversed. He was advised to connect the diagnostic socket centre pin to earth as the internal ECU earth had been damaged when he tried to 'tune' it!, this did work but the fact he had used a scotchlok to connect it wasn't the brightest idea and the earth was intermittent to say the least!
I contacted him and he did the gentlemanly thing and paid for an ECU repair.
I sent it to Avati Race Parts in Essex, they checked it, repaired it and returned it in a very short time with a 12 month guarantee, total cost was £307 including postage, luckily I wasn't paying!
