Dyno or ECU Flash?
Lazarus
Having received my order from Italy, I have today removed the OEM shotgun silencer from my 2013 Diavel and fitted an 'SC-Project' C/F slip-on end can (SC Project supply the Pramac Ducati team apparently).
The weight difference is reduced from approx' 10Kg to a little over 3Kg, which although fairly obvious as the SC unit is a single oval, might also be a result of the exclusion of that large brown crinkly filter thing at the end of the OEM unit ... A Cat I believe it's called?
Although the Cat may have gone, the OEM O2 sensors are unaffected and I do NOT want to fit a PC3/V as they are a bit pointless below the 5K rpm as regards the 'closed loop' system - Not even adding the O2 eliminators would help much here either (according to Dynojet on the web).
The SC Project team say that no re-mapping is required but, as I am keen to avoid running too lean or too rich with a new engine, My questions are:
Do I need some sort of Dyno session to check the fuel mapping is still okay? Or
Would an ECU tweak or re-flash be a better option?
Thirdly, can Ducati Glasgow do this or will it need to be a Dyno centre?
-LaZ-
Hmm, I've often wondered about this too, my monster can be a cheeky monkey in toon when its hot. Chrisw said remove the exhaust valve and he can mod the ecu to ignore it or something like that.
I've got the dp ecu termis and filter but am still convinced it is fuelled and mapped to suit the powers that be !
Personally, cost aside, rolling road and reflash ( I think )
Aren't they all lean to give max mpg ?
I never did like the look of the big silver Diavel Termi Slip-on and I certainly didn't want to pay a small fortune for the full system, especially as it is not road legal. Hence the C/F SC Project unit and the questions.
There are lots of other options I think, like going with the Diavel DP Race ECU, depending on the cost versus a reflash. I may even get the DP air filter or perhaps a K&N unit to finish it off?
Decisions, decisions ....
Can you buy a DP race ECU on its own?
-LaZ-
