Ducati timing Belt Test
PMSL I'd be very concerned buying from anyone who thought that was a method of testing a belt. Belts don't load up like that in an engine......
We did loads of testing with how load is applied as we had certain riders who could snap a belt using just the force from pedalling, the way they delivered power made a huge difference.
even funnier they actually push the fact that teeth are made out of soft rubber, tooth jump which you really don't want on a cam shaft, is a controlled by tension and tooth interface (shape/material), if its soft it'll slip over the sprocket tooth easier and with less force. We had to increase the tooth height to reduce tensions on pedal bike system, Gates have machines which you can measure the load need to cause a tooth jump which accurately measure the torque needed to do this.
I learned a lot doing that pedal bike project and know that there is a lot more to how a belt functions than a simple tensile strength test especially when it bears no relationship to what goes on in an engine. We didn't have the complexity of the effect at high temperatures to contend with in the material construction which really does add to the problems as it'll deteriorate a belt quickly if its made from the wrong materials.
I guess Cyclewworks want to sell their belts so just use a simple advertising method to do it, the crap bit of the t'internet is that its all too easy for sh1te like that to form peoples opinions :(
PMSL I'd be very concerned buying from anyone who thought that was a method of testing a belt. Belts don't load up like that in an engine......(
Yeh.............original Duke kit for me, would'nt trust a cycle company!!!:lol2::D
that ad video is what i'd call rubbish...
you have no way of knowing the weight of the van at any time,
how old any belt was ,
what type of machinery were the belts from,
and as the man says, thats not what they are used for.
a load of bull.
This link was posted up here before a few months ago.
Think my comment was along the lines that it only tells you which belt makes the best towrope.
Perhaps it is a good belt but their own disclaimer about not being scientific means it is mildly interesting but factually inconclusive.
