In connection with my little project to fit a pair of RWU Ohlins to my '21 Z900RS I am looking for a front axle that will fit my Ohlins before I resort to getting something purpose made.
The end on the axle needs to be 32mm diameter to fit one of the fork legs without using any split collar arrangement, (which I want to avoid, the split collar arrangement).
Overall length of the axle needs to be around 250mm ish..
The threaded end of the axle will need a collar of some form, but I am not worried about that end as if the worst comes to the worst I could make something suitable to the correct dimensions & thread size.
The actual diameter of the axle isn't too much of an issue either as I can hopefully just change the wheels bearings to suit whatever axle I might end up using.
So, what I'm really looking for are any Ducati models, or any other make for that matter, that use an axle that has a 32mm diameter end on it as standard.
If anybody has an axle that they could measure for me please & let me know what model it is for I can have a search on the internet to see what might be available to purchase "off the shelf" so to speak.
Wheel wise I'm looking at using OZ Gass items so I'll just order the front wheel to suit whatever bike the axle comes from.
Front brake discs will be ordered using similar criteria or if all else fails, custom carriers will be made. But, I'm hoping there are existing parts out there that will do the job.
Cheers guys
Cheers guys
