Ducati 999 problem ?
geo31
sick Ducati 999 Help
Hi guys I have a 2003 999 with 14k on the clock last week my bike started making a whining noise coming from the engine on the belts side, so i done the obvious thing and checked the tension on the belts and the condition and they look ok both have the same tension but in doing so i have noticed when i squeeze the horizontal timing belt the center pully on the crank shaft moves slightly towards the front of the bike about 0.5mm - 1mm.
Should there be any movement there?
Where else could the whine be coming from? the tone of the whine lifts when reving the engine.
hopefully some one might be able to help?
thanks
Geo31
If the movement is at the layshaft pulley (arrowed in the picture below) you have a serious problem. A replacement bearing only costs a few pounds but the crankcases have to be split to change it!
If the movement is at one of the other two pulleys (fixed idler or tensioner) the bearings are easily changed.
If i squeeze the belt arrowed in yellow then the center pulley moves along the green arrowed line about 0.5mm to 1mm.
I take it thats bad?:o
[/IMG]
Yes that's bad. If you similarly squeeze the vertical belt I wouldn't be surprised if the pulley moves vertically too.
Sorry to be the bearer of bad news. There is a slight, very slight, chance that the pulley is loose on the shaft. You should check the nut is tight.
I've just been and looked at a duc 998 engine with 3000 miles on it and the lay shaft has the same movement as mine does.
Is that just a coincidence or normal then?
Maybe it is then, but I wouldn't expect 0.5mm -1.00mm play on a shaft that's supported on ball bearings at each end. I wouldn't expect any perceptible play at all.
I had a listen to this bike last week over in Largs. Closest sound it reminded me of would be a car alternator with a knackered pulley bearing, although someone did ask if it could be an induction sound, but then what do I know:dunno:
If it was an aircraft I might be in with a chance cos they make really loud noises when they're kn@@kered and leak their life force all over the tarmac, generally we try to fix em before the punters get on board:D
I've had the engine casing off this morning and found the primary shaft bearings are knackered, one of them is jamming so I guess that was possibly the whining noise?
I think a trip to ducati Glasgow is next.
the expression Ouch comes to mind i think
It was very reasonable actually £14 for the bearings and £7 for the oil seal. I can do all the work myself so a cheap repair.
Apart from the 3 week delivery on one of the bearings ;-(
Engine rebuilt with the new bearings and the fecking noise is still there. So it looks like it's coming from the gearbox?
Does the shaft in the gearbox turn even when the engine is running in neutral or only when a gear is engaged?
The mainshaft (with the clutch on the end of it) turns all the time unless the clutch is disengaged. The layshaft (with the sprocket on it) only turns when a gear is engaged, although it often spins slowly in neutral due to oil drag.
When the mainshaft is turning all of the gears are rotating, but only the one that is engaged is driving the layshaft.
So does that mean if the bike is in neutral and the clutch is removed then only the crank shaft is turning then?
Not quite. The gearbox will be completely stationary but the primary drive gears will still be rotating. The driving gear is on the end of crank and the driven gear behind the clutch drum supported by a bearing on the end of the gearbox main shaft. Have a look at the parts diagrams and you'll get the idea.
Bike now stripped ready to drop the engine out tomorrow.
Fingers crossed it will drop out with no problems!
Luckily, I'm half deaf, and that's before I put ear plugs in.
I don't have to hear (and stress about) strange noises coming from my bike...I can live in blissful ignorance until it explodes...
I've been following this as I have the same issue. I had the shop try and track it down. They removed the entire clutch, checked the bearing for play...solid. Removed the cam belts, checked the layshaft for movement, solid. Removed the entire clutch for a better listen and it seems with a doubt it's coming from the vertical cylinder near the tensioners and cams. Now if I had an older engine with cams running in steel ball bearings we might have found an answer, but my cams run in plain bearings. I'm also running a larger 1038cc bore kit, slipper clutch, light weight flywheel and DP light weight cam belt pulleys. As I said, they replaced the tensioner bearings and re-adjusted the belts. It could have been doing this all along, noises are mysterious, you think you hear one and it's always beend there. Anyone know what the conclusion is to this members problem?
I dropped my 999 off at the shop for a listen. Coming from the left side alternator area. Tech believes it's a gear mesh as it's not a bearing noise. At first the tech thought it was the belts rubbing on the inside of their covers. But he's heard this noise before and it could possibly be the two starter gears in need of a shim ? The shop installed a new sprag, starter gears, bushings, etc this past April. I also had a new starter installed in September. So I hope this helps diagnose some one else's problem. The shop is pulling the alt. cover off tomorrow if they can get to it.
