Ds engine noise advise
seant
Can anyone coment on engine noise from the ds1000 in my sport classic?
Took it out today for the first time after winter rest.
Started and sounded as normal.
Road for about 20 miles engine temp up to 97c stopped at junction and the engine sounded very noisy, rattleing like a dry clutch and right from the heart of the engine.
Went back home so bad and Tracy agread loads of noise.
After half hour fired up again 60c sounded normal.
So noisy when hot and hot quite quickly?
Any thoughts??
Any thoughts??
Difficult to diagnose noise problems without hearing them but presume you have correct amount of oil in bike? Just when you say it just had a service I wonder if that was a coincidence as oil and filter would have been done at same time.
Noise from the engine when hot could suggest a problem with bearings etc. (which could have been caused by lack of oil)
With older cars it was standard to throw in heavy oil in the car just before selling it as that stopped the death rattle temporarily of failing big ends etc.
Hope it's not anything like that. If it is mechanical noise and engine related I would be very wary of running it anymore than you have to until you get a verdict on the problem.
Engines will sound different hot to cold though. 2 years ago on way back from a run with one of the old bikes I thought I heard a "different" noise and within 5 miles had convinced myself the engine was about to disintegrate. Was just a figment of my imagination.:o
I agree with Stewart and if in any doubt get it checked. Odd how this should happen immediately after a service.
Contact DG - I believe it's still under warranty and if there's a problem - probably better not to run the engine.
Geoff
