Deep sump oil mesh
  • Thread starter Thread starter alane
  • Start date Start date
A
alane
Just visiting
Help please - how do I get the oil mesh out from the deep sump opening?
Does it unscrew or pull off or is there a screw up the Middle of it?
In between showers of rain and lying on the floor this is becoming an epic oil change!
Drain the oil (thanks Derek ;) )
got the oil filter off - eventually using a big pipe wrench
Went to put oil drain plug back in and I've been given the wrong size gasket :mad:
Also been given wrong shape gasket for the deep sump/mesh filter cover :mad: .
Hopefully it's gonna be a 14mm allen key....
It wasn't/isn't.
Still got the mesh in place and a plastic tube up't'middle of it.
I can just about poke me little finger between the tube and outer thing abnd feel it is the mesh.
I can put a little pressure on the edge of the mesh and see it move slightly.
But I'm buggered if I now how to get the mesh out.
Can't help you with this bit Alane, I have't done an oil screen on a Testastretta engine yet. Mine unscrews with the 14mm allen key on the opposite end of the plug spanner.
T'was push fit.
small 12mm dia o-ring at top of filter and larger 25mm dia o-ring at base of filter.
Stubby pliers gripped the plastice 'up' tube and gave it a tug.
Just seemed to be a few bits of gasket edges about the size of a gnats whisker at the bottom of the filter.
Filter pushes back in and held in place by o-rings.
Voila.
