Cylinder Head Nut Tool
Mr-Superlight
For my rebuild of a 900 (Monster) engine I think the only specific tool I'll need is the one for the bolts atop the head - is the Ducati tool as good/cheap as any or is there a cheaper alternative I might source ?
Quick search on Amazon found these Laser ones - can get delivered next day with Prime for £35. Should be ok ?
I made one like this
Thanks Mike - I've now ordered one of those as both myself and my mate that is helping me out may well find we use these a few times so, for the pretty small cost it is worth us having one.
Andy
Just needs to be used at a right angle to the torque wrench so the extra length has no effect on the reading
I've found the clutch locking tool very handy to have. I've you are into frequently taking Ducati engines to bits then the cam nut tool, valve spring tool and primary drive puller make things a lot easier.
Agreed, some can be made with relative ease too. Definately second the clutch basket tool. I have an Oberon.
If anyone needs a 4V cam locking tool, I have a one that DIDNT work on my ST4s as no hole was drilled in the centre!
I was going to return it but got sidetracked (as usual).....
