CLutch engaging real hard. Please help.
Red Wraith
I just replaced the clutch on my 05 999. I use the Gen 2 basket and Barnett clutch pack. Today was the first day I've actually been able to get out and really ride to check it out. I noticed when I shift gears, it's almost slamming into gear. It's engaging really hard.
I just bled it again and it still had some air in the line. I made sure all the air was out and went for another ride. The problem still persists. Can someone give me an idea to what the problem could be? :confused:
Thank you.
No I didn't. I was assuming the Barnett clutch pack I got was pretty much a plug and play. Where can I find out what the height is suppose to be?
This is how i do it on a normal clutch. not a slipper.
38mm stack height. you can get the correct height by swapping the
2mm and 1.5mm steel plates.
you must start with a 2mm steel and you end with a steel next to the pressure plate.
brian.
Good deal. I'll find what my height is suppose to be and check it.
I was just told on another forum that I should have 1-2mm between the first steel plate and the pressure plate. Any idea if this is a good way to check it or not?
New issue. I pulled the pressure plate off and the pushrod came out with it. I tried to put the pushrod back in and it will not go in all the way. This happened the other day when I installed the clutch but I figured someone had pumped the clutch lever, so I opened the slave cylinder and the reservoir and bled the system. All was good to go. This time I KNOW no one has touched the clutch lever and yet the pushrod will not go all the way back in. Any ideas?
If you pull the lever in try turning the pressure plate by hand if you
find it stiff your clutch is dragging ,and the pressure plate is not clearing the clutch pack.which could be to high so would require
dropping down by using the steel plates 2mm/1.5mm to get the correct stack height.
brian.
The clutch slave cylinder has a spring behind the piston.
so when you took the p/plate off and the push rod came out the spring in the slave cylinder would have pushed the piston out over just like some one had pulled the clutch lever .
It should just push back with the push rod and the p/plate.
make sure you put some grease on the push rod when you put it back in.and some in the clutch plate lifter in the middle of the pressure plate release bearing.
brian.
Thanks Brian. I got everything back together. I just need to find out what my stack height is suppose to be. Apparently it's something top secret since I can't find it anywhere.
I swapped out the 2 thick plates for two thin plates from my old set and got a 38mm stack height. It's a little better but it seems to still engage a little hard. I don't know if this is typical or not considering the only one I have to measure it against is the clutch that was on the bike when I got it. The old friction plates were worn to almost to nothing and the basket was beat to death.
