Chiz's 900SL (ALMOST GOING)
Latest update
Bike runs fine.:D
It sometimes will not turn over & the problem now is that the connector & cable going into the starter is corroded to hell.:mad:
Anyway, problem solved me thinks:idea:
Cable ordered up & should be here for Saturday I hope;)
Looks like it will be going early next week & 100% tip top condition.
Then it will be put away on Tuesday night to sit another 2 weeks.:mad:
:thumbs:At least I know I will return to a gleaming new 900SL when I get home.:thumbs:
Thanks to all the Ducati mechanics & gurus for your input.
The drinks bill will be high when I see you.:eek::eek:
Have you been riding it to work ? :lol2:
He sure hasn't been bringing it to any SDC events! :p :lol2:
Think Chiz and Davieravie are forming the non-riding branch of the SDC.
It's ok Chiz I know you would attend if you could. When does the Asbo expire? :flash:
Don't Tar me with the DavieRavie brush please?;);):p:p
The 848 has been out & about most days in my time off.
Just been my training for the "OTHER SPORT" has taken up all my SDC meets.
PLUS the offshore earning a crust hassle.
Saw another new SDC events I wont make.:mad:
When I do get to meet you all it will be like meeting old friends again. Thats if I remember your names.:p:p
Bike runs fine.:D
Now that you've confirmed the corrosion; change the cable of course, but it's also worth taking the solenoid out, cleaning and lubing the shaft (ooo-err) and checking the coil tube for any corrosion.
Shouldn't take to long and well worth doing since yer down there anyway. ;)
Be very careful with the connection onto the starter motor, they can be corroded and swine if they snap.
I renewed the side earth strap, main battery earth, used MUCH heavier cable to starter motor and even fitted a starter solenoid from a mini (car) of all things to improve starting.
Uprated battery and better coils turned out to be the best mods, however.
Good hint I was given was to crank the bike with the clutch lever pulled in so it reduces the start load, seems to help.
Good luck - Frank
appears my project superspurt is coming out in sympathy,turning over fine but not firing,getting a spark and fuel...fired up fine t'other day tae..:confused:
