charging problem with my 996
Blind Pew
got a problem, my battery keeps dying. i have fitted a new battery and had it shunt tested and its fine. i have tested the charge going to the battery and the readings are 3.5amps no load and 15amps with full beam on.(should this be more) i have a datatool veto plus alarm fitted that seems to be ok the only things i have found on my constant breakdown journeys have been, original battery had a duff cell and the internal battery in the alarm needed replacing. i could disconect the alarm but i need to know if the charge rate is correct?
Dunno too much from a technical angle but I had loads of battery probs on my 996 till i junked the alarm, it was meta system 3. Also suggested is the proper Yuasa acid battery as opposed to the cheaper gel replacements. Never needed Optimates or anything thereafter.
Check the battery voltage when the bike is running. It should be between 13.5v and 14.5V when the engine is at 2-3000rpm. Anything less and it is undercharging, much more than that and it is overcharging and will knacker the battery.
