Changing engine mode settings.
It will just go from the screen after a short while and the dash will return to its normal display, no need to key off and on again.
It seems you’ve sussed it Gim 👍
It’s all on page 108 onwards of the manual.
Just remember to highlight the Memory icon at the bottom of the screen and keep it highlighted, ie the ‘menu/enter’ button on the LHS switchgear pressed, it turns green and says ‘memorised’.
Definitely doesn't deault to home screen on mine when I've done all that.
I can set all the parametres in my chosen mode, press and hold memory unti it memorizes and stores my settings, and when I've done the last one Exit will take me back to the start of the list again, and no amount of waiting will take it back to the home screen. It stays on the parametre menu forever unless I switch off the igintion.
Sorry to pile onto your thread, this just gets a bit under my skin. I have spent a great part of my life in time and effort to achieve the level I ride at. im not really fast but fast enough for me. I have worked hard to reach the point where my roll on is proper for my lean angle and still have some slip/slide but remain in control and on line. The new bikes allow you to be much more reckless without consequences. I am not against these things I just believe that skill must be learned and see this as a short cut. The quote from a bike mag sorta sums it all up: "it used to be that you were a hero of you exited a turn, bike still partly leaned over with the front wheel in the air and ths bars crossed up, now with electronics, even a total neebie can feel like a hero"
Not sure rider aids will make a hero out of a zero.. the aids may alow you to go faster more safely but it won't improve your reaction time or race craft or running wide and into the gravel before you even get to test ya cornering abs...I think they just alow newbies to fuck up at a higher speed than they previously would!
I've mixed emotions about the whole thing.. many racers have spoke out about the use of electronics on modern machines , saying it takes the skill out of it. I guess, in part, they mean you had to have bigger balls back in the day... could the same be said about lapping the iom on a sixties brit bike with square tires compared to an early 90's bike? Where is the cut off for technological advances? Not just anyone can ride a motogp bike, many have tried and failed. Yes, alot is politics and team funding but despite all the rider aids, it takes a very special rider to master em.
I thought you meant when you’re selecting riding modes whilst riding (or stationary)
If you just tap enter menu it will take you straight to the rider modes, not the settings menu, and there's no way to get out of it without turning the ignition off and starting again.
For sure, if you’ve gone into the Settings Menu you have to manually exit from that, but you can only access that whilst stationary anyway.
However, when changing riding modes, it should just go back to your normal screen once the new riding mode is selected or if you do nothing. Otherwise you wouldn’t be able to change the riding mode on the fly.
Yes, that's right. The rider mode menu will cancel after a few seconds if you don't do anything. But when customising the mode in the settings menu it seems odd that there's no way of exiting or pressing "finished" when you've done to return to the home screen.
IMO when successfully completed not only should there be a finished button but pushing it should produce an audible round of applause.
I always thought you just wheelie to the point you want to save and then press the OK button?
Never been any good at wheelies. In5hink it's a weight thing. I've a mate that's a fat Guinness ( no, not exige) that is awesome at em. He's a fat Guinness and just leans back when he wants it to pop up. He once did a wheelie on his 990 ktm that lasted 2 weeks! Only stopping for food and toilet breaks.. he's also Australian so may be exaggerating.. they do that....
Thanks to the advice given here, I did not get the emergency alert, but my wife's phone did.
I just had that, i was just about to take a Boss zombie out and it fucking ruined it, bastids!!
