What kind of LED unit have you got, a bulb or a circuit board? If it's a bulb, don't waste your time. It will actually be less bright than the original because it can't make use of the reflector.
If it's a circuit board, you may have to file down the corners to make it fit, I did. Also remember to cover the back of it with a couple of layers of insulation tape to make sure that the various metal fittings inside the light unit don't short out the circuit.
