Andy,
A jam jar and a bit of plastic tube to go on the nipple is all the kit you need.
Assuming you are getting fluid from the nipple but still no clutch action. There are two problems to overcome when bleeding the clutch.
The first is getting air out of the slave cylinder. To overcome this, take the cylinder off the bike. loosen the bleed nipple and push the piston all the way in with your thumb. While holding the piston in, tighten the bleed nipple. That should evacuate the air from the cylinder. It's a bit tricky on your own but can be done.
The second problem is air getting trapped at the master cylinder banjo. This can be tackled 3 ways.
Method 1. Get a rag and wrap it loosely around the banjo to catch fluid that will come out, loosen the banjo slightly with a spanner, pull the clutch lever to the bar, tighten the banjo again. This should be sufficient to clear the air, if not do it once more.
Method 2. Lean the bike to the right so that the master cylinder is higher than the banjo then "jiggle" the lever until the air bubbles stop emerging from the wee hole in the bottom of the reservoir.
Method 3. same as method 2 except unbolt the master cylinder from the bars so that you don't drop the bike while trying to lean it over
