Bike/Bike intercom systems
Gizmo
Forum Geek
I'm after a bike/bike intercom system which can also be used rider/pillion and 1 base needs to be able to swap off the multi onto the 999.
Anyone got any suggestions as to what will work well and where to buy?? I had a look at Autocom but am now totally confused cos there's so many bits.
Jez, never thought i'd be asking that on a public forum, {clicks link to http://www.gwocgb.co.uk/} maybe i should ask there? :)
Mikey,
I've an older autocom on mein panzer. It still does pretty much everything - rider to pillion, music (with auto fader when someone talks), phone (with auto fader when someone talks) and just a few weeks ago I added a Kenwood TK3207 (plus interface) for bike to bike capability.
Like I said, it's an older version and something that's on my list of things to replace at some point.
I do believe the new models are much better, but even ours is still pretty good at everything (though not yet tried the bike to bike out yet).
There's a few out there and I've heard good things about Starcom as well.
I would agree that it's a bit confusing looking at the brochure - but they're very helpful on the phone and you can buy direct.
I'd recommend going with the Kenwood radio too - we've also got the motorola PMR's that Autocom sell, while they're a bit smaller than the kenwood, the kenwood has a metal chassis and feels much more robust and is defo less fiddly. Also, I think it would be prudent to add a PTT button for your bike to bike side of things.
I've just had a look through the new brochure I have here, and if I were to buy a new system just now I'd be buying the super pro avi (kit 300) setup. Mainly for the noise cancelling headsets but also because it seems to have a lot more adjustability built in.
You may prefer something a bit smaller though if you need it to be portable and not fixed to any one bike in particular.
Errr. not sure I've helped any mate - but you've got my number if you wanna talk about it.
Cheers!
i came to same conclusion Scott, the super pro gives a lot more features and when you add the extras in like mains power etc it isn't so bad but you need to double everything for 2 bikes :eek:. radios are expensive, we've got a couple at work we use on downhill photoshoots ( its handy to tell the photographer a few seconds before riders appears) might nip in and see what models they are and find an interface lead.
it is confusing with so many parts and options and probably worth a call, i may nip up to the local autocom dealer today anyway just to see what they suggest. It'll be almost £800 to kit both bikes out :eek:
Mine can go in a tank bag, got bags for both bikes and it'll be easy to swap, i'll add power leads to both bikes.
Scottch said:
Mikey,
Cheers!
A friend of mine (yes i have got one) used the starcom system when he travelled to france last year with his wife on her bike he said it was really good ,very clear sound up to 100mph and never gave any trouble,hope this is of some use:thumbs:
Mikey,
I don't think you would need to double up.
Like you say, you could put everything in the tank bag and just run a power interface cable up to that from the front of the saddle. I've seen that done before. Then it's just a case of moving the tank bag from bike to bike.
You do now get bluetooth headsets to retrofit to your existing helmets. I know this will give you rider to pillion and the phone, but I'm not sure if you can use this for a music or PMR interface.
It's not too hard to install yourself either - I managed to do das panzer meinself, and it has a similar (CANBUS) type of electrical system as the duc'
Just do take plenty time doing the headset install so it's comfy!
thanks Gordon, just looked at their site and it does seem like a decent, better priced option.
Scottch said:
Mikey,
yup, i do need 2, I want it so i can chat to linzi on her RS so she'll have the other one.
plug into multi is no problem , i'll double the heated grip socket as it actually runs the GPS not the grips which are hard wired. i'll link a fused wire off 999 battery to the same 3 pin socket the multi has then i can connect gps and intercom to that, GPS can live in tank bag on 999 as well :)
bike to bike intercom
for the record, I am just about to fit a Starcom Bike to Bike as well as rider pillion. looking at both Autocom and Starcom, I cant say there was that much to chose between the two. however, I got better vibes and totally non pushy sales department at Starcom. Wonder if its an idea to have a log of all riders who have comms facilities, thinking especially of putting them to use during ride outs and stuff.
PS the Starcom web site has a massively convincing video they run to show the quality of their unit. The technical man at Starcom went to great pains to tell me how they authentisised (is that correct spelling?) the experiment. ;)
hello all
I have experienced scala Q2 and blueant intercom F4.
scala is nice product. The blueant disconnects from the friend when she gets more than 400 m behind and it doesn't reconnect aparently the scala system will still reconnect and battery life lasts a hell of a lot longer.
also above 65-70, my blueant F4 starts annoying noices, so it becomes impossible for me to enjoy music or stay connected with riders. Its just a useless device for me. so I would recommend scala to every one.:chill:
+1 for the Scala,
Ive used both an old Autocom and the Scala and the Scala is so much more convenient to use.
Only downside of the Scala is the mic position needs to be "just right" otherwise the voice activation picks up the wind noise.
I had an Autocom & took it off after one ride cos i was @@@@ed off with
"Look at that over there"
"Are we nearly there"
"Slow Down"
"SLOW DOWN"
"AARRRGHHHHHH"
"Oh my god"
Once was enough , never again. Silence is golden..
